The LAG instance specified is not within the valid range of instances.
Check for the LAG instance value. Specify a LAG instance between 0 and MAX.
Error
LAG instance %inst% specified is out of range. Valid range is between 0 and %max%
| Name | Type |
| inst | uInt |
| max | uInt |
